MSM system folder path does not appear to be set correctly
March 11, 2013 3:57am
  • #1 / Mar 11, 2013 3:57am
    Simple_HQ
    Hi
    I have recently purchased MSM but am having trouble getting it to work. I have followed the docs to a tee but have had no luck.
    I have completed the following:
    1) Installed and activated the add-on
    2) Created a new site (did not copy anything from site 1)
    3) Updated URL to root directory in Admin > General Config
    4) Created a new template group and made default for site2
    5) Added site 2 to hosting
    6) Ensured “open_basedir” has been turned off
    7) Copied admin.php & index.php from site 1
    8) Updated system path in admin.php & index.php to absolute URL of site 1 (other variables also updated to reflect site 2 cp url & url).
    9) Uploaded admin.php & index.php to site 2
    10) Reload the site but get the following message:
    Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php
    I am hosting (reseller) with e2 and they have assured me that open_basedir is disabled on the sites.
    I have tried relative links for system paths but get the same result ( ../../username/public_html).
    Does the name of site 2’s admin.php & system name need to be the same as site 1 (I have changed it as a security precaution) ?
    Any help of feedback would be appreciated.
  • #2 / Mar 20, 2013 10:15pm
    forecepts
    Hi guys
    I also have same issues as you.
    May I know how you to resolve this issues?? Thanks
  • #3 / Mar 25, 2013 6:47pm
    Simple_HQ
    Hi @forecepts,
    I haven’t been able to resolve the issue unfortunately. I have a feeling it may have something to do with the fact I am using a reseller hosting account.
    Who are you hosting with and are you also using a reseller account?
  • #4 / Mar 25, 2013 8:30pm
    Kaori
    Hello
    While I don’t have a reseller account, I use a VPS account, this is what I did, so maybe this will help you.
    My EE site is located at the /public_html/ folder for Site1
    1. On the cPanel for my main domain I created an addon domain for site2.com, that automatically created a folder named “site2” on my site1’s /public_html/ folder.
    2. Inside Site 1 Expression Engine Control Panel, went to Site 1 > Edit Sites and clicked the “Create New Site” button.
    3. Created a New Site with the following information
          -Label: Site 2
          -Site Short Name: site2
    4. Duplicate index.php and admin.php from my Site1 /public_html/ folder
    5. Updated the duplicated index.php and admin.php with the information from Site2 (example bellow)
    6. Uploaded both files to the folder /public_html/site2/
    INDEX.PHP
    *  System Path
     * The following variable contains the server path to your
     * ExpressionEngine "system" folder.  By default the folder is named
     * "system" but it can be renamed or moved for increased security.
     * Indicate the new name and/or path here. The path can be relative
     * or it can be a full server path.
     * <a href="http://ellislab.com/expressionengine/user-guide/installation/best_practices.html">http://ellislab.com/expressionengine/user-guide/installation/best_practices.html</a>
     $system_path = '../system';
     *  Multiple Site Manager
     * Uncomment the following variables if you are using the Multiple
     * Site Manager: <a href="http://ellislab.com/expressionengine/user-guide/cp/sites">http://ellislab.com/expressionengine/user-guide/cp/sites</a>
     * Set the Short Name of the site this file will display, the URL of
     * this site's admin.php file, and the main URL of the site (without
     * index.php)
         $assign_to_config['site_name']  = 'site2';
         $assign_to_config['cp_url'] = 'http://site2.com/admin.php';
         $assign_to_config['site_url'] = 'http://site2.com';
    ADMIN.PHP
     *  System Path
     * The variables set the Short Name of the site this admin.php file
     * will log into, and its URL.
  • #5 / Mar 25, 2013 9:14pm
    forecepts
    And please include .htaccess as well in sub-site
  • #6 / Mar 25, 2013 9:26pm
    Kaori
    @forecepts
    Did you manage to get the MSM working for your site?
  • #7 / Mar 25, 2013 9:30pm
    forecepts
    Yes, I can. I follow the docs on ellislab too. But I added addiional file which is .htaccess
  • #8 / Feb 10, 2015 4:12am
    vpavlovic
    I have the same issue after fresh install. Giving up on the ExpressionEngine.
