RTE does not display
November 17, 2012 4:48pm
  • #1 / Nov 17, 2012 4:48pm
    ZacWoe
    I made sure that in add ons < modules, RTE is installed.
    Clicking on ‘Rich Text Editor’ I also made sure that RTE is enabled.
    In ‘My Account’ section ‘Rich Text Editor Preferences’ it is enabled too.
    In Channel XXX > Edit preferences, the option ‘Display Rich Formatting Buttons’ is set to ‘yes’.
    But when I publish an article in this XXX channel, there is not RTE buttons that display.
    Have I missed anything?
  • #2 / Nov 19, 2012 3:08pm
    Shane Eckert
    Hey there ZacWoe,
    Can you tell me what version of ExpressionEngine you are currently using?
    Thank you,
  • #3 / Nov 20, 2012 12:14am
    ZacWoe
    Hi Shane,
    I run ee 2.5.3.
    Thanks.
  • #4 / Nov 20, 2012 10:38am
    Shane Eckert
    Hey ZacWoe,
    What do you have set in your custom channel fields for the text area? Did you select the RTE field?
    Did you also enable the RTE extension in Modules—>Extensions?
    Thank you,
  • #5 / Nov 21, 2012 6:56am
    ZacWoe
    Hi Shane,
    Thanks to your hint to look in custom channel field. I coul find the issue.
    I forgot to click ‘Show Formatting Buttons’ in the custom fields settings.
    Thank you,
    Zac
