Conditional comparing numbers not working
November 09, 2012 11:30am
  • #1 / Nov 09, 2012 11:30am
    Rob Allen
    EE2.3.1
    I have two channel entries tags, both identical except each variation needs to look up a number that’s stored in a custom field, and output less than, or more than totals, called by a simple conditional.
    Field data_distance stores a number, eg 12.05947 or 2936.939, and there are entries that can be filtered (I output “all” data elsewhere so I know it’s there!).
    Here’s my basic code:
    {exp:channel:entries channel="data" search:data_type="Redeem" dynamic="no"}
    {if data_distance <= '50'}
    {if count == total_results}Total results {total_results}{/if}
    {if data_distance > '50'}
    The first tag has 1 out of 4 available entries to display, but total_results is blank (no output at all).
    The second tag has 3 out of 4 available entries to display, but total_results outputs “4”, not “3” as it should do.
    Stumped!
    Any ideas?
  • #2 / Nov 09, 2012 2:42pm
    e-man
    What happens if you use {if data_distance <= 50} sans single quotes?
    Scratch that :I
    The search parameter will only work with fields of the type “Text Input”, “Textarea”, and “Drop-down Lists”.
    http://ellislab.com/expressionengine/user-guide/modules/channel/channel_entries.html#search-field-name
  • #3 / Nov 10, 2012 5:21am
    Rob Allen
    Scratch that :I
    Hi e-man
    Yes have tried all sort sof variations 😊
    I’m not strictly using the search parameter here…
  • #4 / Nov 10, 2012 8:43am
    e-man
    Do any of your entries have a status of some kind? Are they all ‘open’?
  • #5 / Nov 12, 2012 5:04am
    Rob Allen
    Hey e-man.
    Just open and closed statuses, so nothing special!
    What is strange if I output
    Distance is below 50,
    ...it outputs Distance is below 50, Distance is below 50, Distance is below 50, Distance is below 50, Distance is below 50,  etc - so it is seeing the data, just ignoring count/total results.
  • #6 / Nov 12, 2012 9:59am
    glenndavisgroup
    What if you try:
    {if data_distance <= '50' && count == total_results}
    {if data_distance > '50' && count == total_results}
    Mike
  • #7 / Nov 12, 2012 10:10am
    Rob Allen
    Thanks for the idea Mike, but still no output with that.
  • #8 / Nov 12, 2012 11:00am
    e-man
    This is too weird… what happens when you output just:
    {count} - {total_results}
  • #9 / Nov 12, 2012 11:06am
    Rob Allen
    That just outputs the total as you’d expect 1-28, 2-28 3-28 etc.
    By rights it should just work shouldn’t it!
  • #10 / Nov 12, 2012 12:36pm
    Shane Eckert
    Hi Rob,
    What do you see when you enable the Template Profiler?
    I am wondering if the value is being picked up in time or if it just loops through the text.
    Can you enable that and see of you can spot the break down as the parser works through your code?
    Thank you,
  • #11 / Nov 12, 2012 12:51pm
    Rob Allen
    Hi Shane
    Not sure exactly what to look for:
    [MOD EDIT] removed content
  • #12 / Nov 12, 2012 12:51pm
    Rob Allen
  • #13 / Nov 13, 2012 5:10pm
    Shane Eckert
    Hey there Rob,
    I think this might be quicker if I get in a take a look.
    Please be on the lookout for an email from EllisLab.
