Checkbox's not saving in publish form (not safecracker)
November 01, 2012 7:50am
  • #1 / Nov 01, 2012 7:50am
    Ace Prod
    Hi guys,
    for some reason when I edit an entry that was created before I added a checkbox custom field, by checking the form. It doesn’t save that I have checked the field. Is there an obvious solution?
    The chap in the post above describes my problem perfectly, solved it but doesn’t share the solution.
    My details:
    v2.3.1
    Build: date 20111017
    Thank you!
  • #2 / Nov 05, 2012 11:26am
    Shane Eckert
    Hey there David,
    Is this in a SC form or in the Control Panel?
    Are you using any Add-Ons and can you make sure that they are up to date?
    2.3.1 is an older version and there are many bug fixes in place for 2.5.3. You may want to consider updating ExpressionEngine pretty soon.
    Thank you,
