Let me just say off the bat that my EE 2 experience is limited, the following is based on a large site I did in EE 1:
The way I’ve handled this in the past was to completely design the site for one region. Then I went back through the code and replaced any reference to a specific region with variables. Each region had about ten variables declared at the top of each page. This allowed the pages to be local to the end user, but still only have one page of code. Then I created different template groups for each region (i.e. usa, australia, and japan). Each template group contains the same code in each template with only the variable declarations changing.
To manage your images, keep all universal images in one place (i.e. yoursite.com/graphics/). Then any images that will change from site to site should share the exact same name and pixel dimension. The only change is that they are in a region specific subfolder of your main graphics folder (i.e yoursite.com/graphics/usa/). You then reference that graphic with one of the variables you defined (i.e. yoursite.com/graphics/{region}/logo.jpg).
How you structure the actual content of your site will depend greatly on how much content there will be. If you want fewer weblogs to maintain, you can use one weblog across multiple regions by offering a drop down where the content editor can select a region. Then when displaying the content you display only the region that is defined for that template group. (i.e. search:region_customfieldgroup=”{region}”). Using the same weblog across multiple regions works technically, but if they do not speak the same language in all regions, your content entry instructions may not help the content editor.
Having 4 sets of identical template groups that all must be updated any time you make a change won’t be that bad. Having 24 probably will be. If you need to streamline the process, you can enable php parsed at imput (security implications there) and upload all your variables (named for the region) to one folder and all templates (generic) to another. Then do a standard php embed on the actual template file within EE. Like this:
<?php include_once ("includes/variables/usa.php"); ?>
<?php include_once ("includes/templates/contact_info.php"); ?>
That would allow you to update for instance the contact info page and pass the changes to all regions. At least in EE 1, you will give up a few things with a php embed. For instance, if you are embedding php files with the above method, you can not use {current_time} within your template. It won’t get processed.
I’ll cut off my long response there. Feel free to ask me more questions if any of this is helpful to you.
