Expression engine files in sub directory
September 20, 2012 2:08pm
  • #1 / Sep 20, 2012 2:08pm
    Dotwebs
    I can’t find the answer to this anywhere and I’m sure it’s quite simple. I have my site testing in a sub directory: e.g. http://www.mydomain.com/mysite so all the EE files are in the folder ‘mysite’. When I go live with the site I want it to show at: http://www.mydomain.com. How can I do this without having to move all the EE files?
    Thanks.
  • #2 / Sep 24, 2012 1:47am
    Kevin Smith
    Hi Dotwebs,
    Even though you won’t fully be moving servers here, this article in the User Guide will help you make sure you’re checking all the right spots. Depending on your host, you may or may not need to move servers, but you’ll want to get with your host to see what they need to do on their end. Either way, though, that article shows you all the spots in the CP where you’ll need to update your site’s URLs and file paths.
    Hope that helps!
  • #3 / Sep 24, 2012 4:45am
    Dotwebs
    Hi Kevin,
    That’s great, thanks for the reply.
    Dorothy
  • #4 / Sep 24, 2012 5:36pm
    Kevin Smith
    Sure thing, Dorothy. Anything else we can help with?
