Help with Switchee
September 18, 2012 10:36pm
  • #1 / Sep 18, 2012 10:36pm
    xenowebdev
    Hey guys,
    I’m currently updating an EE1.7x ecommerce site using CartThrob to EEV2.x.
    I needed a way of showing discounted pricing on the front end. The client didn’t want to go through 3000+ products and change the sale price on each, so I am allocating a ‘status’ of Discount5, Discount10 etc to each product and then using a math plugin to display the discounted price.
    I’m trying to use the ‘status’ parameter in a switchee statement as follows to reduce overhead - before I was just using ‘if statements’:
    {exp:channel:entries channel="products" url_title="{last_segment}" dynamic="no" disable="category_fields|pagination|member_data" status="open|Discount5|Discount10|Discount15|Discount20|Discount25"}
    {exp:switchee variable='status' parse='inward'}
     {case value='Discount5'}
         <div class='OldPrice'>NZ${exp:number_format number='{product_price}' decimals='2'}</div>
         <div class='ProductPrice'>NZ${exp:math:percentMe num1='{product_price}' num2='5'}</div>
     {/case}
     {case value='Discount10'}
         <div class='ProductPrice'>NZ${exp:math:percentMe num1='{product_price}' num2='10'}</div>
     {/case}
     {case value='Discount15'}
         <div class='ProductPrice'>NZ${exp:math:percentMe num1='{product_price}' num2='15'}</div>
     {/case}
     {case value='Discount20'}
         <div class='ProductPrice'>NZ${exp:math:percentMe num1='{product_price}' num2='20'}</div>
     {/case}
     {case value='Discount25'}
         <div class='ProductPrice'>NZ${exp:math:percentMe num1='{product_price}' num2='25'}</div>
     {/case}
     {case default="yes"}
         <div class='ProductPrice'>NZ${exp:number_format number='{product_price}' decimals='2'}</div>
     {/case}
    {/exp:switchee}
    This breaks the page layout at the price.
    I’ve tried it without using the other plugins but same result. Have also tried it without the “default=‘yes’” and just a ‘value=“open”’ instead.
    Can anyone see what’s going wrong?
    Cheers
    Steve
  • #2 / Sep 18, 2012 10:53pm
    John St-Amand
    Got it:
    Should be
    {exp:switchee variable="{status}" parse="inward"}
  • #3 / Sep 18, 2012 10:58pm
    John St-Amand
    If that doesn’t work, what result do you get with something like this:
    {case value="Discount5"}
     Discount5 is my status
    {/case}
     {case value="Discount10"}
    Discount10 is my status
     {/case}
         Discount15 is my status
     {/case}
    and you could repeat this if needed…
    {/exp:switchee}
  • #4 / Sep 18, 2012 11:09pm
    xenowebdev
    Just in case anyone else is following:
    The issue was that I had nested 2 Switchee blocks, therefore one was closing out the other before running.
    Ended up using Marks other plugin, “IfElse” inside the first Switchee block to run my check against the statuses.
    Many thanks to John for his help 😊
  • #5 / Sep 24, 2012 10:44am
    Vertexer
    You can also nest switchee by leaving off the ‘exp:’ in nested tags.
    Outer switchee block:
    {exp:switchee ...}
    Nested switchee block:
    {switchee ...}
