Filename error and importing entries
September 15, 2012 8:23pm
  • #1 / Sep 15, 2012 8:23pm
    Alfredo Canales
    I used data grab to import some entries
    On the ones with images im getting this error when i try to edit them
    A PHP Error was encountered
    Severity: Notice
    Message: Undefined index: filename
    Filename: libraries/File_field.php
    Line Number: 77
    I also uprgade EE form 2.4 to latest version don’t know what caused this. Any ideas?
  • #2 / Sep 18, 2012 11:57am
    Shane Eckert
    Hello Alfredo,
    It sounds like you may need to update your Add-Ons and check your field types.
    Are you using SafeCracker File or File?
    Please let me know.
  • #3 / Sep 18, 2012 11:59am
    Alfredo Canales
    I’m using file.
    What do you mean upgrade add-ons ? Upgrade the file field type?
    How can i do that?
  • #4 / Sep 18, 2012 12:03pm
    Alfredo Canales
    Oops forgot to add. This isnt happening just with the DataGrab addon.
    I just tried to post a new entry on the site. Not the ones i’m importing and i’m still getting the same error. So its not an Add-on problem. I posted another thread about this.
  • #5 / Sep 18, 2012 3:19pm
    Alfredo Canales
    Shane
    Can you please help me out with this? It’s kind urgent client can’t publish and new entires right now.
  • #6 / Sep 20, 2012 4:13pm
    Shane Eckert
    Hey Alfredo,
    With all the cases you have open. I am a little confused on where you are with things.
    I would like to login and try and get all your issues taken care of. Are you open to that?
    Please let me know!!
