SafeCracker return not working after successful save
September 04, 2012 9:51pm
  • #1 / Sep 04, 2012 9:51pm
    gsl_admin
    Hi All,
    Having a bit of a frustrating time here.  I’m working on a very very dead simple SafeCracker form.  3 fields, nothing spectacular.  I’m sure that it’s just that I’m doing something stupid, but for some reason once I submit the form it returns to a blank page.  Now, all the data is being saved correctly, and I’ve turned on the debugging and I’m not getting errors, the return is just not working for me for some reason.  Here is my form:
    {exp:channel:entries channel="vendors" author_id="{member_id}" status="open" limit="1"}
        {exp:safecracker channel="vendors" entry_id="{entry_id}" return="profiles/profile" include_jquery="no" safecracker_head="no"}
    <ul>
        <li>
          <label class="required"><div>{label:shipping_policy}</div><span>{instructions:shipping_policy}</span></label>
          <textarea name="shipping_policy" class="textarea large">{shipping_policy}</textarea>
        </li>
        <li>
            <label class="required"><div>{label:refund_policy}</div><span>{instructions:refund_policy}</span></label>
            <textarea name="refund_policy" class="textarea large">{refund_policy}</textarea>
        </li>
        <li>
            <label class="required"><div>{label:customization_policy}</div><span>{instructions:customization_policy}</span></label>
            <textarea name="customization_policy" class="textarea large">{customization_policy}</textarea>
        </li>
        <li class="form-footer">
            <button type="submit" class="bttn-green"><span>Save Policies</span></button>
        </li>
    </ul>
        {/exp:safecracker}
    Am I missing something here?  Like I said before, I’m super frustrated right now, so just a fresh pair of eye can probably pick out whats wrong.
    Thanks for your help.
    ~ Lucas
  • #2 / Sep 06, 2012 2:26pm
    Dan Decker
    Hi Lucas,
    Thanks for posting your questions on the forums!
    Thank you for providing the template code, that’s a great first step!
    Let’s look at what you’ve got going on here. You’ve wrapped SafeCracker in a channel entries pair. What are you trying to do there? SafeCracker can work independently based on information in the URL.
    One other thing that stands out is the safecracker_head parameter. The use of that expects that you intend to place the {safecracker_head} tag elsewhere in your template, within the SafeCracker tags. SafeCracker still needs the code in the head, the parameter just lets you relocate it in the event it could conflict.
    On a related note, the query_no parameter expects that you are supplying your own version elsewhere in your template.
    Now, give this a try for me:
    {exp:safecracker channel="vendors" entry_id="{segment_3}" return="profiles/profile" include_jquery="no" safecracker_head="no" author_only="yes"}
    <ul>
        <li>
        </li>
        <li>
        </li>
        <li>
        </li>
        </li>
    </ul>
    {safecracker_head}
        {/exp:safecracker}
    This revision tells SafeCracker to expect the entry_id in segment_3 of the URL and the author_only parameter makes sure only the author, logged in, will be allowed to edit the entry.
    Let me know if that works!
