Need a secondary {title} --> {url_title} custom field -- Does it exist?
August 25, 2012 6:38pm
  • #1 / Aug 25, 2012 6:38pm
    Brainwrek
    I’m building a new SAEF and I need a set of custom fields that acts like the default {title} and {url_title} fields.  When something is entered into {custom_field_1} a url-safe version is auto-copied to {custom_field_2}.
    Wondering if there’s already a plugin/add-on for this out there?  I’ve spent quite a bit of time scrolling through the fieldtypes on Devot:ee, but haven’t found anything yet.
  • #2 / Aug 26, 2012 8:28am
    John Fuller
    I haven’t had to do something like this for quite some time, so I’m working off fuzzy memory. There is a lot that EE can handle automatically in regards to titles in the SAEF. Try hard coding a title in the SAEF (hidden field) and then submitting a few entries. I believe EE automatically adds an increment to the title name and then auto creates a URL friendly url_title based on that title. If that doesn’t help you, then provide more details.
  • #3 / Aug 26, 2012 2:17pm
    Brainwrek
    Hi John.  Thank you for taking the time.
    Yes, you’ve nailed it.  I will be auto-generating the ‘official’ {title} and {url_title} fields (via hidden form fields) exactly as you mentioned.  But I want the user to have an option to add his/her own “Pseudo” Title (ie a secondary title)—which should then auto generate a “Pseudo” URL_Title.  My reasoning for doing so is a bit complicated, so I’ll save you the details.
    BUT… for anyone else who needs to do something like this, here are a couple of links that describe crafting a similar setup using Javascript.
    http://stackoverflow.com/questions/3823784/jquery-set-text-to-lowercase-and-replace-space-with-hyphens-on-keyup
    http://www.mediacollege.com/internet/javascript/text/case-lowercase.html
  • #4 / Aug 26, 2012 4:12pm
    John Fuller
    Maybe create a custom member field for this, wrap the SAEF inside the custom profile data tag and then output that field to the SAEF title? I have never done that but it think it should work.
    http://ellislab.com/expressionengine/user-guide/modules/member/index.html#custom-profile-data-tag
