Form help
August 24, 2012 3:02pm
  • #1 / Aug 24, 2012 3:02pm
    Brian_az
    Hello,
    I am trying to use a contact form and pre-populate using the value= field. The following form below sends all the data properly but the value field is not showing.
    Can anyone advise on how to make the value field work?
    <pre><code>
    <!—Contact form—>
    {exp✉️contact_form user_recipients="false" recipients="myemail" charset="utf-8" return="http://domain.com/domains"}
    <label for=“from”>Email Address:</label>
    <input type=“text” id=“from” name=“from” size=“40” maxlength=“35” value=”” /></p>
    <input type=“hidden” id=“subject” name=“subject” size=“40” value=”{title}” />
    <label for=“message”>Message:</label>
    <textarea id=“message” name=“message[]” rows=“10” cols=“40” value=“I would like make an offer on {title} of:“t” ></textarea>
    Please enter the word you see in the image below:
    {captcha}
    <input type=“text” name=“captcha” value=”” maxlength=“20” /></p>
    <input name=“submit” type=‘submit’ value=‘Send’ /></p>
    {/exp✉️contact_form}
    <!—/Contact form—>
    <pre><code>
  • #2 / Aug 27, 2012 9:40am
    Ralph
    In textareas you put the value between the tags.
    <textarea id=“message” name=“message[]” rows=“10” cols=“40”>
    </textarea>
  • #3 / Aug 27, 2012 9:55am
    Kyle Cotter
    Hi Brian,
    As Patrick points out, you need to put your content in between the textarea tags.
    Check out the sample contact form from the user guide for a working example of how this tag operates.
    Let me know if you have any questions.
