Comment moderation not functioning
August 09, 2012 6:19pm
  • #1 / Aug 09, 2012 6:19pm
    Frog
    I have a default member group set up for new accounts with minimal privileges. Under the member group settings I have ‘Exclude member from comment moderation’ set to No. However, when I login to test and post comments they bypass comment moderation and are visible straight away.
    Any ideas?
    EE. v.2.5.2
    Thanks…
  • #2 / Aug 10, 2012 2:12pm
    Kevin Smith
    Hi BP,
    That’s a system-wide setting for members of that group when they try to post a comment on a channel that has comment moderation turned on. I suspect you don’t have comment moderation turned on in the channel in question here. To do so, go to Admin > Channel Administration > Channels. Under Comment Posting Preferences, be sure “Moderate Comments?” is set to Yes.
  • #3 / Aug 11, 2012 6:48am
    Frog
    Hi Kevin,
    Thanks for the info. Odd thing is I’m sure I checked this before posting here. Have just double checked and all channels are set to to Moderate Comments – Yes. And everything seems to be working fine now. I’ve just test posted in every channel and all comments have been sent for moderation. Really not sure what’s changed but the problem seems to be resolved.
    Thanks again.
  • #4 / Aug 13, 2012 4:09pm
    Kevin Smith
    No problem, glad I could help point you in the right direction! Let us know if we can help again in the future!
