Ever since upgrading from 1.X to 2.X I have never quite been able to get Moblog to work. Since I had other more pressing issues, I just skipped over it and forgot about it. When I got my handy dandy iPhone, I figured I’d just use the mobile templates. Those were buggy and did not work *at all*. Now that I have my iPad, I can just use the regular site well enough I can post entries on the go ... except for photos.
So back to Moblog I go to try to make it work. The problem is, I keep getting these errors at the top of my site (where the check moblog tag is):
A PHP Error was encountered
Severity: Warning
Message: file_put_contents(/photo.JPG) [function.file-put-contents]: failed to open stream: Permission denied
Filename: moblog/mod.moblog.php
Line Number: 1950
A PHP Error was encounteredSeverity: Warning
Message: Cannot modify header information - headers already sent by (output started at /home/user/public_html/system/codeigniter/system/core/Exceptions.php:170)
Filename: core/Common.php
Line Number: 408
I also get the following errors when I try to “check moblog” from the control panel:
Severity: Warning
Line Number: 1950
Filename: libraries/Functions.php
Line Number: 806
Line Number: 806
Line Number: 402
Clearly, I have goofed something up somewhere, but I don’t have a clue where to start in order to fix this.
v2.5.2 - Build Date: 20120606
