How to Link to First Entry in First Subcategory from Category Page?
June 21, 2012 9:42pm
  • #16 / Jul 06, 2012 12:26pm
    Shane Eckert
    Hey msmith29063,
    Thanks for letting us know.
    Is there anything else I can help with?
  • #17 / Jul 21, 2012 6:39pm
    msmith29063
    The Child Categories add-on won’t work. Too many limitations I think.
    I’m trying to work it out with a query now. Here’s an example of what I’m trying to do in the embed:
    {exp:channel:entries channel="vessels" category="{exp:query sql='SELECT cat_id AS subcat_id FROM exp_categories WHERE parent_id = {embed:category_id} ORDER BY cat_name LIMIT 1'}{subcat_id}{if no_results}{embed:category_id}{/if}{/exp:query}" orderby="vessel_order" sort="asc" limit="1" dynamic="no"}
    <a href="http://{title_permalink=%27vessels/view%27}/" title="{embed:category_name}">{embed:category_image}__{embed:category_name}</a>
    <small>{exp:query sql="SELECT count(exp_category_posts.entry_id) AS post_count FROM exp_category_posts WHERE exp_category_posts.cat_id = {embed:category_id}"}{post_count}{/exp:query} vessels</small>
    Or this:
    {exp:query sql="SELECT cat_id AS subcat_id FROM exp_categories WHERE parent_id = {embed:category_id} ORDER BY cat_name LIMIT 1"}
    {exp:channel:entries channel="vessels" category="{subcat_id}" orderby="vessel_order" sort="asc" limit="1" dynamic="no"}
    {if no_results}
    {exp:channel:entries channel="vessels" category="{embed:category_id}" orderby="vessel_order" sort="asc" limit="1" dynamic="no"}
    {/exp:query}
    Obviously, these won’t work. But this is what I’m trying to do. Any recommendations?
    Thank you.
  • #18 / Jul 23, 2012 4:57pm
    Dan Decker
    Hey Mathew,
    I’m sorry the add-on didn’t cut the mustard.
    Code sample one won’t work at all. You can’t put module (Query) tags in as parameters, ExpressionEngine’s Parse Order won’t dig it.
    On sample 2, any time you have module (Query/Entries/Query) tags nested, you are likely to have trouble.
    The step would be query->result->embed and so on until you have your result you’re after.
    What I’d really like to do is get into your install and play with this to see if I can’t get a solution for you. You cool with that?
    Be on the lookout for an email from me.
