Data exporting from Expression Engine 1.7 to 2.5
June 06, 2012 12:29pm
  • #1 / Jun 06, 2012 12:29pm
    Danh H.
    I am in the process of moving my websites from EE 1.7 to EE 2.5. What is the best way to export data from 1.7 to 2.5?
    Is there a step-by-step guide I can find somewhere?
  • #2 / Jun 06, 2012 3:16pm
    Danh H.
    Is there a built in tool to export data from 1.x into 2.x? I would also like any suggestions on plug-ins or modules to export data that you might recommend.
  • #3 / Jun 06, 2012 3:17pm
    MrBaseball34
    You mean that the upgrade process doesn’t do it for you?
  • #4 / Jun 06, 2012 4:51pm
    Danh H.
    @MrBaseball34: I’m also moving the site to a new server. I should have mentioned that in my post. 😊
  • #5 / Jun 07, 2012 9:41am
    Danh H.
    So basically—I’m looking for an easy solution to xport my data from EE 1.7 so I can put it in a new installation of EE 2.5 on a new server.
  • #6 / Jun 07, 2012 12:48pm
    Shane Eckert
    Hey Danh,
    Thank you for posting your question here on the ExpressionEngine forums.
    You can follow this Moving ExpressionEngine to Another Server guide to better help with the process.
    Most users have success with exporting the data from one DB and importing the data into the new DB. Can you give that a try?
