Understanding and using most common htaccess directives for a CI website
April 22, 2012 5:18pm
  • #1 / Apr 22, 2012 5:18pm
    novice32
    In the past I merely lifted htaccess code from online but never really understood how parts of it worked. So, I attempted to add some documentation around 3 common scenarios 1) forcing “www” version of your website 2) enabling web-friendly URLs and 3) forcing specific pages to be HTTPS (this works in localhost vhost setup with self-signed cert).
    Let me know your thoughts, suggestions, or if I completely missed the mark with anything. Feel free to add as well.
    RewriteEngine on
    Options +FollowSymLinks
    #force redirect to "www" version of the URL
    #also appends REQUEST_URI (i.e, $1) to redirected version of URL
    #tell browser or agent this is a permanent redirect
    RewriteCond %{HTTP_HOST} ^domain1\.com
    RewriteRule ^(.*)$ <a href="http://www.domain1.com/$1">http://www.domain1.com/$1</a> [R=permanent,L]
    #rewrite friendly URL and pass to CI web app in proper format (i.e, which includes "index.php")
    #ignore requests made directly to index.php, robots.txt, favicon.ico
    #or files in folders images, assets and js
    #example rewrite: <a href="http://www.domain1.com/web/about">http://www.domain1.com/web/about</a> => <a href="http://www.domain1.com/index.php/web/about">http://www.domain1.com/index.php/web/about</a>
    RewriteCond $1 !^(index\.php|images|assets|js|robots\.txt|favicon\.ico)
    #GOAL: force https for login page
    #IF request on port 80 and not made directly to index.php, robots.txt, favicon.ico
    #THEN create a rewrite rule for URI /user/login  to redirect ("Found 302") to https
    #version of URL. "$1" backreferences "(.*)", which is anything appended after
    #after "/user/login". "$1" appends additional data to the secured version of the URL
    RewriteCond %{SERVER_PORT} 80
    RewriteRule /user/login(.*)$ https://%{HTTP_HOST}/user/login$1 [L]
    #force https for registration page
    RewriteRule /user/register(.*)$ https://%{HTTP_HOST}/user/register$1 [L]
  • #2 / Apr 22, 2012 9:03pm
    skunkbad
    It is not PCI compliant to force HTTPS. you should instead send a 404 error.
  • #3 / Apr 22, 2012 10:08pm
    novice32
    Thanks Skunkbad - interesting point. Strictly speaking, for an e-commerce website, you would want to throw a 404 for a non-secured version of resource, endpoint, or page; this allows strict following of the API.
    My website doesn’t perform e-commerce. I’m currently enabling HTTPS for only a few pages (login, change password, register). I couldn’t find an easier way to force SSL for certain pages, generically, that would work for both localhost and on live website.
    I figured the above - provided correct - could be a learning resource for folks who don’t quite understand htaccess. The one implied flaw is if the visitor is on a HTTPS page and clicks on a “relative” href link, then the HREF page will also be secured, even though it may not have been intended. One could add another rewrite rule to force non-targeted SSL page back to HTTP.
  • #4 / Apr 22, 2012 10:24pm
    CroNiX
    Lines like this:
    would be much better written as:
    So you don’t have to constantly readjust it every time you add a new directory, file or whatever, that you don’t want CI to execute.
  • #5 / Apr 23, 2012 9:02pm
    novice32
    Thanks, CroNix, that’s certainly a more elegant solution.
