Member Login Problem on Multi-Language Site
April 04, 2012 6:14am
  • #1 / Apr 04, 2012 6:14am
    daniel.kaminski
    Hello,
    the multi-language alternative, where a sub-directory is used for each language seems to break my member log-in, that is, if I’m not missing something.
    The starting point
    I have two language directories, say en/ and de/ each with their respective index.php and .htaccess files. The htaccess files also eliminates the index.php in the uri’s. The multi-language set-up itself works like a treat, with a language switch and a small custom plug-in visitors can switch languages at any point and also third party add-on navee was a nice fit for fulfilling the multi-language requirement. So far so good.
    The problem
    Now when I implement a log-in form it only seems to actually work from within root directory. When I’m trying to log in from /en or de/ I’m not authenticated and i’m redirected to http://mydomain.com/mydomain.com/de .
    Does anybody have an idea where where my problem could be?
    Daniel
    Reference index and .htaccess alterations as used
    E.g. the /en/index.php got the following two lines added:
    $assign_to_config['global_vars']['language'] = "en";
    $assign_to_config['site_url'] = getenv('HTTP_HOST') . "/en";
    and the system reference to the system path was altered
    $system_path = '../system';
    and the /en/.htaccess looks as follows:
    <IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteBase /
    # Removes trailing slashes (prevents SEO duplicate content issues)
    RewriteRule ^(.+)/$ $1 [L,R=301]
    # Enforce NO www
    RewriteCond %{HTTP_HOST} ^www [NC]
    RewriteRule ^(.*)$ <a href="http://domain.tld/en/$1">http://domain.tld/en/$1</a> [L,R=301]
    # Removes index.php
    RewriteRule ^(.*)$ /en/index.php/$1 [L]
    # If 404s, "No Input File" or every URL returns the same thing
    # make it /index.php?/$1 above (add the question mark)
    </IfModule>
  • #2 / Apr 04, 2012 2:37pm
    daniel.kaminski
    Problem solved. Just in case somebody else encounters the same problem: the reason was the definition of the site_url config variable:
    I had the following in the /de/index.php file:
    $assign_to_config['site_url'] = getenv('HTTP_HOST') . "/de";
    The login form was rendered with an action attribute of “mydomain.com/de” which obviously is not correct.
    So simple fix is to add the http protocol in front:
    $assign_to_config['site_url'] = "http://" . getenv('HTTP_HOST') . "/de";
  • #3 / Apr 05, 2012 10:31am
    Shane Eckert
    Hey Daniel,
    I am glad to see that you were able to get this working. Nice bit of work!
    If you do need anything else in the future, please let us know by opening a new thread.
