Removing Comment Module causes Errors with Existing Content
March 16, 2012 12:24pm
Subscribe [0]
  • #1 / Mar 16, 2012 12:24pm
    UKFreelancer
    I removed the Comments Module as it is not required.
    When I now try to Edit an existing in any Channel I get the following error:
    A Database Error Occurred
    Error Number: 1146
    Table ‘innovation.exp_comments’ doesn’t exist
    SELECT `entry_id`, COUNT(*) as count FROM (`exp_comments`) WHERE `entry_id` IN (‘24’, ‘17’, ‘16’, ‘15’) GROUP BY `entry_id`
    Filename: C:\wamp\www\system\codeigniter\system\database\DB_driver.php
    Line Number: 330
    UKFreelancer.
  • #2 / Mar 16, 2012 12:45pm
    UKFreelancer
    You can close this.
    I found the bug fix, hopefully 2.5 will fix this?
    UkFreelancer.
  • #3 / Mar 16, 2012 8:14pm
    Sean C. Smith
    Glad you found the fix. Closing this at your request.
    Sean
