Hi all,
I’ll try to keep this short, thanks in advance for reading.
I’m a designer with limited PHP experience. I can do basic stuff without any problems, but customising a CMS may cause some issues.
I’ve always been aware of Expression Engine, but I’m unsure if it’s the right solution for an upcoming project.
Technically I’m not doing anything too extravagant, but in terms of the sheer amount of pages, content and sections in the project I’m working on, I’m not sure if it’s the right option!? In some cases there may be 50+ pages across 5/6 levels of content across 100 or more regions.
Please find the EE.png diagram attached to help you understand what I’m talking about. Please note the likes of Region 1 and Region 100 saved me from doing 100 separate branches. I also haven’t filled out every branch, the top level should give you an indication of how it would look across sub branches.
A few questions 😊
If I was to code the templates, would Expression Engine be able to handle that so many levels of pages? Would it become messy and unmanageable in the admin area? In terms of generating the navigation for each section, sub sections etc?
Is is possible to create user groups and give them different views of the site, i.e. hide some levels of the navigation according to assigned user group?
How does the search work, do you apply tags / keywords per page?
In terms of actual content, is it possible to repeat ‘content modules’ across numerous pages?
When working in the admin area, there may be a lot of data entry in tables, with LOTS of columns and rows. How does EE treat tables? Do you code them by hand in ‘html’ areas, or would you enter data into set fields?
Is it possible to upload multiple images per page template?
Does payment for the commercial license of Expression engine allow me to roll out multiple sites on the same server?
How does Expression Engine handle custom Jquery? Can I use any libraries or tools I wish?
Is it possible to run Expression Engine on the likes of Dreamhost?
This is all I can think of for the minute. Any response or help would be much appreciated.
Aaron
