Clean URLs with categories: more than 3 segments
February 27, 2012 4:29pm
Subscribe [4]
  • #1 / Feb 27, 2012 4:29pm
    e.b.
    Hello,
    I’ve used this code posted at http://fortysevenmedia.com/tuts/ee_cat_url.txt as a basis for one of my channels:
    <!--The Categories Page ///////////////////////////////////////////////////////////////-->
    {if segment_2=="" AND segment_3==""}
    {exp:weblog:categories weblog="yours" style="linear"}
     <a href="http://{path=">{category_name}</a>
    {/exp:weblog:categories}
    <!--The Category Entries Page ///////////////////////////////////////////////////////////////-->
    {if:elseif segment_2!="" AND segment_3==""}
    {exp:query sql="SELECT cat_id FROM exp_categories WHERE cat_url_title = '{segment_2}'"}
     {exp:weblog:entries weblog="yours" category="{cat_id}"}
         <a href="http://{title_permalink={segment_1}/{segment_2}}">{title}</a>
     {/exp:weblog:entries}
    {/exp:query}
    <!--The Single Entry ///////////////////////////////////////////////////////////////-->
    {if:elseif segment_3!=""}
    {exp:weblog:entries weblog="yours" limit="1" url_title="{segment_3}"}
    Call whatever custom fields you have here
    The problem I’ve come across is that I’d like to extend the functionality to segment_4 but can’t accomplish this nomatter what I try.
    My structure is the following:
    {if segment_2!="" AND segment_3==""}
    showing my entries per category:
    <a href="http://www.mysite.com/channel/category/">http://www.mysite.com/channel/category/</a>
    FINE
    <!--The Category Entries Page PER YEAR ///////////////////////////////////////////////////////////////-->
    showing my entries per category AND filtered by year:
    <a href="http://www.mysite.com/channel/category/year">http://www.mysite.com/channel/category/year</a>
    FINE
    required to show the single entry:
    <a href="http://www.mysite.com/channel/category/year/url_title">http://www.mysite.com/channel/category/year/url_title</a> or
    <a href="http://www.mysite.com/channel/category/url_title">http://www.mysite.com/channel/category/url_title</a>
    PROBLEM
    I’ve tried to shift the entry to segment_4 but it doesn’t work.
    So far I’ve been spending 3 days on solving this problem and am quite discouraged. Any help would be highly apreciated!
    Kind regards,
    E.
  • #2 / Feb 27, 2012 5:03pm
    glenndavisgroup
    Hi E,
    Try replacing your:
    with:
    {if:elseif segment_3!="" AND segment_4==""}
    ...your code here
    {if:elseif segment_4!=""}
    ...your code here
    Mike
  • #3 / Feb 27, 2012 6:44pm
    ChiefAlchemist
    Glenn might be correct.
    None the less I’ll add that you might also consider setting dynamic=“no”. Even now and then I’ve run into funk keyword type conflicts. It’s been a while so I can’t give you real example. But it was something like a channel row and a category had the same URL, or something similar.
    The point is, when dynamic=“yes” EE is making some assumptions and doing what is “standard” based on the URL it just parsed. If it assumes wrong then you could get unanticipated results. When you set dynamic=“no” you’re basically tell EE not to assume and that you’ll dictate the nature of the query.
  • #4 / Feb 27, 2012 7:48pm
    Enviromed
    You might consider rethinking this to use laisvunas subsegment addon on devot-ee.
  • #5 / Feb 27, 2012 9:13pm
    ChiefAlchemist
    Linky?
    But more importantly, why go this other route?
  • #6 / Feb 27, 2012 9:29pm
    Enviromed
    It’s so simple. How much is three days of your life worth?
  • #7 / Feb 27, 2012 10:37pm
    ChiefAlchemist
    What’s so simple? The link you posted? Your insights on the tool you mentioned? What is this, an Easter egg hunt?
  • #8 / Feb 28, 2012 4:00pm
    e.b.
    Hi E,
    Try replacing your:
    with:
    ...your code here
    ...your code here
    Mike
    Hello Mike,
    Thank you for your reply!
    I’ve already tried this … doesn’t work. In fact, I’ve already tried everything I could think of of being crucial … Any other suggestion?
  • #9 / Feb 28, 2012 4:03pm
    e.b.
    Hello Chiefalchemist,
    I will have a try with dynamic=“no” before I consider using an add-on. Result will be posted 😉
    E.
  • #10 / Mar 01, 2012 3:27pm
    e.b.
    Hello everybody,
    I had a try with dynamic=“no” and I got no result, which means that the url is properly constructed but the full entry isn’t shown.
    Here is my shortened code for a better understanding:
    1. The category entries listed per year
                {exp:gwcode_catmenu channel="aktuelles" cat_url_title="{segment_2}" style="simple" excl_cat_id="15"}
                   <a href="http://{path=%27aktuelles/{cat_url_title}%27}" class="cur">{cat_name}</a>
                {/exp:gwcode_catmenu}
                <div class="content_text">
                 {exp:yearlist channel="aktuelles" category="13"}
                  <a href="http://{path=%27{segment_1}/{segment_2}/{year}%27}" class="year">{year}</a>
                 {/exp:yearlist}
                 <ul class="article_listing">
                  {exp:channel:entries channel="aktuelles" limit="10" paginate="bottom" orderby="date" sort="desc" disable="member_data" category="{cat_id}" year="{segment_3}"}
                   <li class="click">
                    <h5><span class="date">{entry_date format="%d.%m.%Y"}</span> <a href="http://{title_permalink={segment_1}/{segment_2}}">{title}</a></h5>
    <p>                {aktuelles_subtitle}<br />
                   </li><br />
                  {/exp:channel:entries}<br />
                 </ul><br />
                </div><br />
    2. The single entry
    at http://www.mysite.com/channel/category/year/url_title
    or http://www.mysite.com/channel/category/url_title
                {exp:gwcode_catmenu channel="aktuelles" cat_url_title="{segment_2}" style="simple" excl_cat_id="15" category="13"}
                 {exp:channel:entries channel="aktuelles" limit="1" url_title="{segment_4}" dynamic="no"}
                  <h2>{title}</h2>
    <p>              {aktuelles_body}<br />
                 {/exp:channel:entries} <br />
                </div></p>
    <p>      {/if}
    Adding a segment_3 to
    hasn’t brought me further either.
    Any other suggestions?
    Kind regards,
    E.
