Hi guys,
I hope this will help you.
Problem:
When adding a new entry with is_unique will work just fine but what about when you want to update the entry using the same form validation rule? is_unique will not work because it will detect that you are adding a duplicate entry. Which sucks, and you will be forced to create a new rule just for that.
Prerequisites:
1. when editing, you must pass the primary key as post data (which we mostly do)
Example where user_id is the primary key:
<input type="hidden" value="1" name="user_id" />Benefits:
1. Same form validation rule for editing and adding
Code:
<?php if ( ! defined('BASEPATH')) exit('No direct script access allowed');
class My_Form_validation extends CI_Form_validation {
public function is_unique($str, $field)
list($table, $field)=explode('.', $field);
$q = $this->CI->db->query("SHOW KEYS FROM $table WHERE Key_name = 'PRIMARY'")->row();
$primary_key = $q->Column_name;
if($this->CI->input->post($primary_key) > 0):
$query = $this->CI->db->limit(1)->get_where($table, array($field => $str,$primary_key.' !='=>$this->CI->input->post($primary_key)));
else:
$query = $this->CI->db->limit(1)->get_where($table, array($field => $str));
endif;
return $query->num_rows() === 0;
/* End of file My_Form_validation.php */
/* Location: ./application/libraries/My_Form_validation.php */
