Using Outside JS/CSS
December 29, 2011 9:53am
Subscribe [4]
  • #1 / Dec 29, 2011 9:53am
    nyc
    I’m still in the beginning stages of setting up my file structure but I was wondering how do I set up my EE so I can use CS/JS from the FTP instead of template files?
  • #2 / Dec 29, 2011 11:26am
    Boyink!
    Link to it like you normally would.
  • #3 / Dec 29, 2011 11:27am
    Rob Allen
    First create a folder where your .js files will live, something like /assets/js and upload the files there.
    Then wherever you need to call the JS files in your templates, such as between the <head> and </head> tags just output the javascript tags normally.
    <head>
    <title>My page</title>
    < script src="/assets/js/file.js" >< /script >
    </head>
  • #4 / Dec 30, 2011 4:47pm
    nyc
    Thats how I have it set up now but I guess I was wondering if there was more of an EE way to do things.. thanks to you both
  • #5 / Jan 07, 2012 10:48am
    kaizendc
    I’m having the same problem too, my JS codes are not working,
    my normal folder strucure is
    js/jscode.js
    css/csscode.css
    where should I create a folder to make my code work?
  • #6 / Jan 07, 2012 10:52am
    Boyink!
    You can put js anywhere on the site - you just need to make sure EE can always see the correct path to it.  If it’s not working look at the paths of the rendered code to see if they are right.
