Hi John,
Thank you for replying to my post. The response was found in a post by Joh Gedders:
I had read online that CodeIgniter supported either (or both) MSSQL or ODBC. Since the EE 2.0 rewrite, will you be supporting MSSQL or ODBC in EE?If you don’t immediately support MSSQL or ODBC, do you have any future plans to support it?
Lisa Wess Posted: 21 July 2010 06:36 PM [ Report ] [ Ignore ] [ # 1 ]
EE 2.1 still requires MySQL, and I would recommend making your decisions based off of that requirement.
I am very new to this app. All I know is that I wanted to do a quick install on Godaddy. I changed my ‘system’ directory name once I FTP; I then changed the file permissions to write and read. I then put the following in the url : http://www.niagaraimages.com/systemnewname and it automatically picked up :
http://www.niagaraimages.com/systemnewname/index.php. And the install wizard appeared.
In the settings : I changed the ‘localhost’ to what was mentioned on the GoDaddy community help : Host Name : lnigrostefanchuk.db.7257872.hostedresource.com
I will be able to work on this after work 😊.
I have the latest version of EE. Sorry I have missed something.
Thank you,
Lucy
