expression engine inserting <i> tags everywhere into code
November 10, 2011 1:38pm
  • #1 / Nov 10, 2011 1:38pm
    heaversm
    Hi - I’ve got a weird issue with EE inserting nested <i> tags everywhere into my code. It has something to do with the face that the
     tag is outputting code - and while that code gets put in properly, the <i> tags also appear. Any ideas?
    <pre><section id="project_container">
     <div id="project_view" class="box">
      <div id="project"></div>
      <div id="code">
       <pre>
        {project_code}
       </pre>
    <p>  </div><br />
     </div><br />
     <!—end project view—><br />
     <div id=“project_info” class=“box”></pre>
  • #2 / Nov 11, 2011 8:44am
    Hi, heaversm.
    That’s certainly a weird one.
    Are you using any sort of CSS settings for pre? If I put this code in a template all by itself, I have no context here. Is this inside an exp:channel:entries loop? What’s an example {project_code}?
  • #3 / Nov 17, 2011 12:14pm
    heaversm
    I solved this one - it was a problem with the content contained in {project_code} - I ended up needing to place <pre><code> tags around all the code in the {project_code} field.
  • #4 / Nov 18, 2011 8:22pm
    Sean C. Smith
    Hi heaversm,
    Glad that you have it worked out. I’m closing this thread, but do feel free to post again as needed.
    Sean
