best way to handle sidebar?
November 04, 2011 4:30pm
  • #1 / Nov 04, 2011 4:30pm
    Riverboy
    Hi, i use embed:foobar and then modify the template if needed to add/remove something.
    But i was wondering is there a more simple way to handle all, cos i have 2-4 actual templates that i embed into sidebar of my sites pages, some has 2 some 4.
    cheers
    -pete
  • #2 / Nov 04, 2011 5:44pm
    Rob Allen
    If I have a sidebar that could have 3 or 4 different blocks depending what pages it’s being displayed on, I’ll often use one embed and inside it add a conditional or two depending what I want to show. Other times however I will embed 2 or 3 templates - it really depends on the needs of the site, what’s easiest to manage, and of course what is most efficient.
  • #3 / Nov 04, 2011 5:58pm
    Riverboy
    can you give some simple example how you would do that? thanks.
  • #4 / Nov 04, 2011 6:57pm
    Rob Allen
    Ok, call a single embed…
    {embed='inc/.sidebar'}
    Then in the .sidebar template
    <aside id="sidebar">
    {!-- only show on the home page --}
    {if segment_1 == ""}
    Hello and welcome to my home page
    {!-- show categories always, no conditional --}
    <h2>Categories</h2>
    <p>{exp:channel:categories channel="blog"}<br />
    <a href="http://{path=blog/index}">{category_name}</a><br />
    {/exp:channel:categories}</p>
    <p>{!-- only show recent posts if not in the blog section --}<br />
    {if segment_1 != "blog"}</p><h2>Recent posts</h2>
    <p><ul><br />
    {exp:channel:entries channel="blog" dynamic="off" limit="5"}<br />
    <li><a href="http://{url_title_path=blog/story}">{title}</a></li><br />
    {/exp:channel:entries}</ul><br />
    {/if}</p>
    <p></aside>
    Does that give you an idea Pete?
