I am getting Error Number: 1064 when I try to click on the next pagination link. Here is my code:
{exp:search:search_results}
{if channel_id == 14}{!-- Resources Page --}
<div class="search_result a_closer_look">
<h3><a href="http://{cc_resources_link_url}" target="_blank" rel="noopener">{title}</a></h3>
<p> {exp:trunchtml chars="150" inline="..." ending=" <a href='{url_title_path=consumer_corner/a_closer_look}'>read more.</a>"}<br />
{exp:strip_html}<br />
{cc_resources_content}<br />
{/exp:strip_html}<br />
{/exp:trunchtml}<br />
</div> <br />
{/if}<br />
{/exp:search:search_results}</p>
<p> {if paginate}<br />
<div class='paginate'><br />
<span class='pagecount'>{page_count}</span> {paginate}<br />
</div><br />
{/if}<br />
<br />
You searched for <strong>{exp:search:keywords}</strong> <br />
and got {exp:search:total_results}{total_results}{/exp:search:total_results} result{if "{exp:search:total_results}" != 1}s{/if}.<br />
</div>Here is the error I am getting:
Error
Error Number: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘P50, 50’ at line 11
SELECT DISTINCT(t.entry_id), t.entry_id, t.channel_id, t.forum_topic_id, t.author_id, t.ip_address, t.title, t.url_title, t.status, t.dst_enabled, t.view_count_one, t.view_count_two, t.view_count_three, t.view_count_four, t.allow_comments, t.comment_expiration_date, t.sticky, t.entry_date, t.year, t.month, t.day, t.entry_date, t.edit_date, t.expiration_date, t.recent_comment_date, t.comment_total, t.site_id as entry_site_id,
w.channel_title, w.channel_name, w.search_results_url, w.search_excerpt, w.channel_url, w.comment_url, w.comment_moderate, w.channel_html_formatting, w.channel_allow_img_urls, w.channel_auto_link_urls,
m.username, m.email, m.url, m.screen_name, m.location, m.occupation, m.interests, m.aol_im, m.yahoo_im, m.msn_im, m.icq, m.signature, m.sig_img_filename, m.sig_img_width, m.sig_img_height, m.avatar_filename, m.avatar_width, m.avatar_height, m.photo_filename, m.photo_width, m.photo_height, m.group_id, m.member_id, m.bday_d, m.bday_m, m.bday_y, m.bio,
md.*,
wd.*
FROM exp_channel_titles AS t
LEFT JOIN exp_channels AS w ON t.channel_id = w.channel_id
LEFT JOIN exp_channel_data AS wd ON t.entry_id = wd.entry_id
LEFT JOIN exp_members AS m ON m.member_id = t.author_id
LEFT JOIN exp_member_data AS md ON md.member_id = m.member_id
WHERE t.entry_id IN (6310,4248,5651,5770,6019,5047,5031,4604,4602,4595,4596,4593,4589,4580,4581,4585,4587,4588,4578,4573,4574,4568,4570,4572,4566,4564,4565,4555,4553,4543,4544,4348,4350,4354,4355,4356,4357,4358,4362,4363,4364,4374,4375,4378,4379,4383,4385,4387,4388,4392,4397,4400,4405,4409,4412,4421,4423,4429,4431,4433,4436,4437,4441,4443,4450,4451,4457,4462,4464,4478,4481,4483,4484,4485,4486,4487,4489,4492,4495,4496,4499,4500,4501,4504,4506,4509,4511,4512,4513,4514,4517,4518,4519,4522,4523,4524,4525,4526,4529,4530,4538,4539,4540,4541,4342,4343,4340,4337,4335,4336,4330,4331,4326,4325,4324,4322,4321,4318,4319,4315,4312,4308,4307,4302,4301,4299,4297,4294,4295,4296,4290,4291,4288,4287,4286,4285,4283,4284,4281,4278,4277,4275,4273,4269,4268,4264,4261,4260,4258,4257,4256,4255,4253,4252,4250,5439,5400,5361,4247,4245,4244,4242,4241,4239,4240,4230,4228,4220,4221,4222,4226,4186,4187,4188,4192,4199,4200,4201,4202,4203,4204,4206,4209,4211,4213,4216,4218,4184,4181,4180,4179,4176,4177,4175,4172,4170,4169,4168,4167,4166,3824,3825,4637,4647,4818,6585,6625,6643,6723,6777,6813,6969,6993,7104,7123,7159,7347,7427,7771,7769,7801,7825,7914,7931,7957,8048,8074,60,6412,6337,6068,6174,5491,5647,5930,5713,6038,5984,4882,5113,5018,5200,2028,2029,2031,2032,2033,2034,2035,2036,2037,2040,2041,2042,2043,2044,2045,2046,2047,2048,2049,2050,2051,2052,2053,2054,2056,2057,2058,2059,2060,2061,2062,2063,2064,2065,2066,2067,2070,2071,2072,2073,2074,2075,2076,2077,2078,2139,2150,2152,2154,2155,2156,2157,2160,2161,2164,2172,2174,2175,2181,2186,2187,2191,2196,2197,2199,2200,2201,2202,2203,2204,2210,2212,2217,2218,2219,2223,2225,2226,2229,2234,2240,2241,2242,2243,2244,2245,2246,2247,2248,2249,2250,2251,2253,2256,2257,2258,2259,2260,2261,2262,2263,2264,2266,2267,2269,6246,5459,4973,5356,5414,4626,4608,4685,4726,4860,4835,5833,6470,6550,6742,6791,6880,6991,7049,7272,7412,7513,7573,7743,7799,7851,7930,8014,8061,8099,6309,5537,5513,5650,5595,5767,5752,6018,5074,5032,5438,5399,5360,4643,4770,4819,6451,6496,6586,6623,6641,6715,6811,6970,6992,7031,7092,7106,7344,7426,7469,7495,7772,7783,7812,7820,7911,7929,7955,8046,8068,8106) ORDER BY entry_date desc LIMIT P50, 50The url for this error is:
http://healthnewsflorida.org/search/results/a55c12b590c31467c1fc087702132715/P50
After I search for a term ‘carol gentry’ and click on the first pagination link it goes to the url above where I get the error
Amy
