Can i confirm - as i can find no reference or notes on this - should i be able to use this plugin within a default EE Entries tag?
http://expressionengine.com/downloads/details/magpie_rss_atom_parser/
Because at the moment i have an entire page wrapped in an EE entries tag, and then the side column i wanted to to display info from an RSS feed. This works, the description and link comes in from the feed and displays - but the RSS title is being replaced by the main entries title as they use the same tag.
Now to me - the RSS plugin would either not work at all, or {title} within the plugin would be from the feed and not the main entry.
I know i can work around this by embedding a template, but that is more load on the server for this simple task - so ideally i would like to avoid it. If this is the way it is supposed to work, then no problem, if not, is it a bug?
Thanks N
