Help me find a good solution for this.
September 13, 2011 4:55pm
  • #1 / Sep 13, 2011 4:55pm
    insomnie
    Trying to figure out how to make an entry form for user which he/she can only submit once. This could go to a channel. But the idea is to only enable the user to submit that data once.
    I’ll roughly describe what I need.
    Imagine there is some gameplay that all users can be part of. It’s based on predicting a certain outcome. Lets say for each game a user can submit 5 numbers. There will be multiple games each day but then can only enter each one once.
    I am trying to figure out a way to do this most efficiently. Any suggestion will be welcome.
  • #2 / Sep 13, 2011 5:01pm
    W3 | 84ideas
    If a user submits an entry, the entry will be stored related to a particular game I suppose.
    So now if we query on game_id and member_id, we get either records, or no records.
    If you check that before allowing the member to submit the form, you could check if he already has a record, if so you don’t allow him to do this again.
    Mike
  • #3 / Sep 13, 2011 5:19pm
    LMO
    Another idea that may work is to use the default channel entries loop. If you have each game set to a channel and a member can only see the form if he has no entry in the channel.
    {exp:channel:entries
        channel="game_name"
        author_id="CURRENT_USER"
        {if no_results}
            -- FORM HERE --
  • #4 / Sep 13, 2011 5:38pm
    W3 | 84ideas
    Hi VIM,
    That’s exactly what I meant, thanks for the code example!
    Mike
  • #5 / Sep 13, 2011 5:42pm
    insomnie
    Brilliant! Thank you guys!
  • #6 / Sep 13, 2011 5:46pm
    LMO
    No problem! Any time.
  • #7 / Sep 13, 2011 6:02pm
    W3 | 84ideas
    Welcome!
