comment "url" not being passed
August 31, 2011 7:12pm
  • #1 / Aug 31, 2011 7:12pm
    thefifthlion
    I’m running 2.2.2
    All my fields are being returned on my comment results page except for “url”. It’s as if there is a control panel setting blocking the return of that type of field only. Any suggestions?
  • #2 / Aug 31, 2011 8:56pm
    thefifthlion
    I guess this is only the member url. Not their personal website.
  • #3 / Sep 01, 2011 8:45am
    Hi, thefifthlion. When you say you’re wanting the url variable to be seen, where are you using it?
    http://ellislab.com/expressionengine/user-guide/modules/comment/entries.html#var_url is the page in the docs for it.
  • #4 / Sep 01, 2011 1:27pm
    thefifthlion
    Sue,
    Just wanted to say thanks for all your helpful advice since I’ve signed up!
    Basically I wanted to attached the members url to their screename so it would link to their site. But the url isn’t being passed via {url} for some reason. Have a look. When I use firebug it shows as an empty href.
    http://www.stonehavenjewelry.com/about/testimonials/what_they_are_saying
  • #5 / Sep 02, 2011 1:27am
    Dan Decker
    thefifthlion,
    Do you mind posting the template code where you are wanting to use {url}, that will give us some context and we can help you sort it out.
  • #6 / Sep 02, 2011 12:04pm
    thefifthlion
  • #7 / Sep 02, 2011 12:06pm
    thefifthlion
    I’ve logged in as another member to post an entry and entered a url but when I view the comment on the url is not passed. I thought there might be a “external linking” = off in the control panel or channels somewhere? Thanks for your help.
  • #8 / Sep 02, 2011 4:59pm
    {url_as_author} - give that a try and see if it works.
  • #9 / Sep 02, 2011 5:26pm
    thefifthlion
    where should I use this in the? {url_as_author}
    I’m getting the following html returned back which obviosly is an error:
    pastemployee” class=“bluegreen”>pastemployee
    September 02, 2011
    below are the locations where I added {url_as_author}
    <label for="url">URL:</label> <input type="text" name="{url_as_author}" value="{url_as_author}" size="50" /><br >
    <div><h3><a href="http://{url_as_author}" class="bluegreen">{name}</a></h3>
  • #10 / Sep 02, 2011 5:42pm
    thefifthlion
    got {url} to work, sorry for the confusion
  • #11 / Sep 02, 2011 5:43pm
    Glad you were able to figure out what the problem was. Don’t hesitate to post again as needed.
