EE 2.2.2 + MSM 2.1.0 problem: "The page you requested was not found."
August 22, 2011 6:03am
  • #1 / Aug 22, 2011 6:03am
    Maik Hoogkamer
    I’ve updated one of my EE websites to 2.2.2 (20110801) and updated the MSM in the process as well (2.1.0). All files are in place, but I keep getting the error “The page you requested was not found.”.
    Been searching through the forums, but the suggestions I found did not solve my problem. Also, I don’t see any option to enable the MSM in the general configuration.
    What’s going wrong?
    Edit: I do have MSM enabled in my config file it seems..
    $config[‘multiple_sites_enabled’] = “y”;
  • #2 / Aug 22, 2011 6:28am
    Maik Hoogkamer
    On top of that, I seem to be experiencing the same problems as described here as well:
    http://ellislab.com/forums/viewthread/195651/#922133
  • #3 / Aug 22, 2011 4:21pm
    Kevin Smith
    Hi MH1985,
    Where are you getting the error that says, “The page you requested was not found”? Could you give us some specifics on the different paths and URLs used for your different sites in MSM? How far along in the process of setting up MSM have you gotten?
    Regarding the login problems, are you able to login if you disable MSM in your config.php?
  • #4 / Aug 23, 2011 4:18am
    Maik Hoogkamer
    Hi Kevin,
    I was getting that error when I used the dropdown menu in the top right corner.
    You have the options to switch, view and edit sites from there. For example: /system/index.php?D=cp&C=sites&M=manage_sites
    I have set the config variable as below to disable the MSM and I can login again now, but the MSM is disabled (duh 😉):
    $config[‘multiple_sites_enabled’] = “n”;
  • #5 / Aug 23, 2011 4:27am
    Maik Hoogkamer
    Problem solved Kevin, forgot to add the sites.php controller to my version control. Thus it did not get uploaded. Sorry for my noobism.
  • #6 / Aug 23, 2011 12:10pm
    Kevin Smith
    Hey, no problem at all MH1985. That’s why we’re here!
    Feel free to join us again if you run into any more snags.
