CE image and SQL Query help
August 16, 2011 11:02am
Subscribe [4]
  • #1 / Aug 16, 2011 11:02am
    stevo_s
    Any help as to how to use CE image with an SQL query? it seems to return a blank.
    {exp:query sql="SELECT d.upload_date, d.file_name, c.channel_name
    FROM exp_files d INNER JOIN exp_channels c
    WHERE c.channel_name='portfolios' ORDER BY d.upload_date DESC LIMIT 4"}
    {exp:ce_img:single src=
    {title}
    for some weird reason I can’t put this in the forum code but it should be :
    img src=”{exp:ce_img:single src="{file_name}” width=“120” height=“60”}
    Moved to Community Help forum by Moderator
  • #2 / Aug 16, 2011 11:50am
    Hi, stevo_s.
    Unfortunately we can’t provide direct support for third party add-ons, you’ll need to contact the developer directly. In the mean time, moving to the Community Help forum.
  • #3 / Aug 18, 2011 11:41am
    Est Digital
    Have you tried rel_path instead of file_name?
  • #4 / Aug 18, 2011 2:10pm
    stevo_s,
    Use single quotes when nested within double quotes and it appears fine in the forum
    What appears when you add this?
    <h2>{title}</h2>
    <p>{file_name}<br />
    {/exp:query}
  • #5 / Aug 18, 2011 2:22pm
    stevo_s
    ok thanks.
  • #6 / Aug 18, 2011 2:26pm
    stevo_s,
    Did the query return something for {file_name}?
