curly braces not parsed properly inside of javascript embeds
August 11, 2011 12:40pm
  • #1 / Aug 11, 2011 12:40pm
    northk
    Greetings, I believe I am having a similar problem as reported in the above thread. I have a javascript embed that EE does not parse properly. Here is the code from my embed:
    {exp:channel:entries channel="home" dynamic="no" disable="categories|member_data|pagination" limit="1"}
    // following two lines do not parse correctly
            var params = { allowScriptAccess: "always" };
            var atts = { id: "video-player-ID" };
            ...more stuff here…
    Instead the two vars are rendered without anything inside curly braces, so the code looks like this:
    var params = ;
    var atts = ;
    This causes a Javascript parsing error. So I modified system/expressionengine/config/config.php so it has:
    $config[‘debug’] = “1”;
    This appears to solve the problem. But, I’m wondering if there are ramifications to this which I should know about. For example performance or security (or other parsing) implications. I’m also wondering if this will still work when I upgrade to a newer version of EE (I’m on 2.2.1 right now). Please let me know.
    -NorthK
  • #2 / Aug 12, 2011 4:56am
    NorthK ,
    Debug should be set to 1 and is what is there by default if you install from scratch.
    There are no ramifications from this. Your parsing works as a result of this.
    An upgrade will be no issue for you.
    Does that help?
  • #3 / Aug 12, 2011 11:38am
    northk
    John Henry,
    OK thanks. That’s what I wanted to hear!
    -North
  • #4 / Aug 12, 2011 5:30pm
    No problems. If you run into any issues feel free as always to start a new thread if you have any more questions.
