Using Conditionals to Generate DIV with Entries
August 09, 2011 4:16pm
  • #1 / Aug 09, 2011 4:16pm
    mmcgeeCC
    Preface: I’ve created a jQuery scroller like the one found here: http://flowplayer.org/tools/demos/scrollable/index.html. Think of each image as an entry in one channel. My issue is not getting the scroller to work, but getting ExpressionEngine to display DIVs or not.
    The code that I wish would work, but obviously doesn’t, is below. Note my wish to use the conditionals where they are, which would mean that if there are more than 4 entries, show another div.viewableWindow and show entries. If not, then don’t. Anyone know how I can achieve something like this?
    <div class="window">
         <div class="viewableWindow">
              {exp:channel:entries channel="my-channel" status="open" limit="4" disable="pagination" orderby="expiration_date" sort="asc"}
                   {entry-image}
         </div>
         {if count > 4}
              {exp:channel:entries channel="my-channel" status="open" limit="4" offset="4" disable="pagination" orderby="expiration_date" sort="asc"}
                   {entry-image}
         </div>
         {if count > 8}
              {exp:channel:entries channel="my-channel" status="open" limit="4" offset="8" disable="pagination" orderby="expiration_date" sort="asc"}
                   {entry-image}
         </div>
    </div>
    Thanks for your help.
    EE v2.2.2 - Build: date 20110801
    Moved to Community Help forum by Moderator
  • #2 / Aug 09, 2011 6:28pm
    mmcgeeCC
    I tried an alternative, but it doesn’t seem to be working either.
    My Embedded Template
    {exp:channel:entries channel="my-channel" status="open" limit="{embed:myLimit}" offset="{embed:myOffset}" disable="pagination" orderby="expiration_date" sort="asc"}
         {entry-image}
    My Template
    {exp:channel:entries channel="my-channel" status="open" disable="pagination"}
         {embed="includes/my-include" myLimit="4" myOffset="0"}
       </div>
       {if count > 4}
         {embed="includes/my-include" myLimit="4" myOffset="4"}
       </div>
       {if count > 8}
         {embed="includes/my-include" myLimit="4" myOffset="8"}
       </div>
  • #3 / Aug 10, 2011 10:04am
    Hi, mmcgeeCC - this is a perfect candidate for the Community Help forum, moving there for additional community support.
  • #4 / Aug 10, 2011 12:10pm
    Elemento, Inc.
    Hi i would use this:
    <div> // you need to have an open div
    {exp:channel:entries}
    [...CONTENT GOES HERE…]
    {switch="|||</div><div>"} // this will add a close/open DIV every fourth entry
    </div> // you need to have a closed div
  • #5 / Aug 10, 2011 5:33pm
    mmcgeeCC
    Nice… worked like a charm. Thanks for the help!
