Need help on load view, quick question
July 30, 2011 3:42pm
  • #1 / Jul 30, 2011 3:42pm
    neovee
    The third optional parameter lets you change the behavior of the function so that it returns data as a string rather than sending it to your browser. This can be useful if you want to process the data in some way. If you set the parameter to true (boolean) it will return data. The default behavior is false, which sends it to your browser. Remember to assign it to a variable if you want the data returned:
    $string = $this->load->view('myfile', '', true);
    I don’t really understand the third param, the TRUE or FALSE behaviour. What does returning as a data really means compare to sending to browser? Thanks if somebody can clear this up for me.
  • #2 / Jul 31, 2011 4:24pm
    Eric Barnes
    Returning the data instead of sending to the browser works great for things like loading partials or loading views that you need to access via php latter on. Such as an email template, extra processing, etc.
  • #3 / Aug 01, 2011 3:35am
    neovee
    Can I access a controller files too instead of view files?
