Put Entries in rows of 3 then add code
July 27, 2011 12:09pm
  • #1 / Jul 27, 2011 12:09pm
    Shinetime Media
    I am having issues wrapping my head around an idea I have for a project.
    Here is the idea:
    I want to split up entries into rows of three and then have some extra code placed after each row. Then I want the process to continue until all the entries have been listed.
    Example:
    <div class=“row”>
    <div>Entry One</div>
    <div>Entry Two</div>
    <div>Entry Three</div>
    </div>
    <div>(extra content)</div>
    <div class=“row”>
    <div>Entry Four</div>
    <div>Entry Five</div>
    <div>Entry Six</div>
    </div>
    ...and so on.
    This is probably a very simply process, but I can’t seemed to figure it out. Any help would be greatly appreciated.
    EE 2.2.1
    Build 20110705
  • #2 / Jul 27, 2011 4:20pm
    Adam Wiggall recently posted this solution to the same problem on Google+.  PHP would need to be enabled on your template in order for it to work, as it uses PHP…
    <?php $counter = 0; ?>
    {exp:entries tags}
    <?php $counter += 1; ?>
    <?php if ( $counter == 1 || $counter % 3 == 1 ): ?>
       <div class="row">
    <?php endif; ?>
          <div>Entry {count}</div>
    <?php if ( $counter % 3 == 0 || $counter == '{total_results}' ): ?>
       </div>
    <?php endif; ?>
    {/exp:entries tags}
  • #3 / Jul 27, 2011 4:27pm
    Marcus Neto
    Shinetime,
    Another option is to use the Switch parameter if you are doing this as part of an exp:channel:entries tag.
    Generally speaking to do something like what you are talking about you would do this:
    {switch='||<div>(extra content)</div>'}
  • #4 / Jul 27, 2011 4:57pm
    Switch will only throw that tag in after every third entry though.  If you have a situation with 8 entries instead of 9, the last <div>(extra content)</div> wouldn’t show up.  If that case isn’t a problem (in other words, if you know the number of entries shown will always be a multiple of 3), the switch parameter is probably a better / less complicated option.
  • #5 / Jul 27, 2011 9:56pm
    Shinetime Media
    Nick - Thanks so much man! That is exactly what I was looking for! You have officially put the final touches on a template for me… AND for that I really really thank you.
    Marcus, thanks as I can probably use switch in some other instances. This is an every growing channel in which the count won’t always be a multiple of three.
    Thanks again for all the help!
  • #6 / Jul 28, 2011 2:05pm
    Marcus Neto
    Glad you got it sorted out.
