PHP errors and dropped relationships using SafeCracker
June 28, 2011 10:35pm
Subscribe [10]
  • #16 / Jul 21, 2011 8:51pm
    Jeremy Bise
    If this is helpful, I tried showing the value of the relationship field in my template and what is getting output is a number which is certainly not the ID of the related entry.  I have no ideas where the number is coming from, but it isn’t right.
  • #17 / Jul 22, 2011 12:09am
    aircrash
    I’m still having the problem. I just haven’t had time to troubleshoot further. The php errors are gone in the latest version of ee, but I’m still dropping data from my forms. My live site is stuck at 2.1.3 still because there are some other conflicts under 2.2. My 2.2.1 update is just on my local machine, but I’m out of town until next week. I’ll post my template code when I get back.
  • #18 / Jul 23, 2011 10:20am
    Dan Decker
    Hello all,
    I’m attempting to replicate this issue and will follow up with a bug report if need be.
    Best,
  • #19 / Jul 23, 2011 11:25am
    Dan Decker
    All,
    On a fresh install of EE 2.2.1 I was able to replicate the issue of SafeCracker dropping relationship data.
    In my test, the content of my entry was updated, PHP errors were generated, AND relationship data was lost. The only thing that I wasn’t able to replicate was the incorrect relationship values. My relationship fields contained correct related entry_id values.
    I’m going to file a bug report on this and you can follow along with that here
  • #20 / Aug 02, 2011 5:47pm
    Hybrid Design
    Any progress on this?  We are having the same issue described when trying to about Member Entries using Zoo Visitor (ee-zoo.com)
  • #21 / Aug 04, 2011 1:10pm
    Hi, Hybrid Design. Dan did post a bug report, but there hasn’t been an update yet on that particular one.
  • #22 / Sep 19, 2011 12:22pm
    Wes Baker
    Jeremy, aircrash and Hybrid Design,
    Could you try applying the fix found in this forum post?
    Wes
  • #23 / Oct 09, 2011 6:34am
    Scott Boyde
    I have tried applying the fix but I still have the same issue.
  • #24 / Oct 10, 2011 4:45pm
    Kevin Smith
    Hi Scott,
    You applied the bug fix that’s posted with a solution here? (That one should be the same as the one in the forum thread Wes linked to.)
    Could you double check the fix you applied? That does appear to resolve all the issues we’ve had reported in this thread. If that doesn’t take care of your issues, could you please detail those for us here along with steps that we’ll need to reproduce the problems you’re experiencing?
  • #25 / Oct 10, 2011 5:47pm
    Scott Boyde
    Hi Scott,
    Kevin I have been working on this with Mark Bowen on this thread and seen on the bug report that it may be a duplicate of this thread.
    Would there be sufficient information in my thread or maybe Mark might explain it better. I will try to do the code changes again.
  • #26 / Oct 10, 2011 5:53pm
    Scott Boyde
    I have just tried the code changes again but still the same.
  • #27 / Oct 11, 2011 1:27pm
    Kevin Smith
    Ah, ok. I didn’t see that thread. Looks like we’re duplicating efforts here. I’ll close this thread up then, since it looks like everyone else in the thread had their issues resolved by that bug fix. Since you didn’t, yours may be a related but different issue. We’ll keep working with you on this over at this thread.
