URL Help
June 19, 2011 11:44pm
Subscribe [4]
  • #1 / Jun 19, 2011 11:44pm
    Danny Valle
    I am trying to understand the URL structure in EE2.  I understand the URL structure (http://www.something.com/templateGroup/templateName).
    My question is, why am I able to type in any string after the template group segment or template name and the page still loads? For example, I can type in the following (http://www.something.com/templateGroup/templateName/someRandomText) or (www.something.com/templateGroup/someRandomText) and the page still loads.
    Shouldn’t I get some sort of error??  It’s strange because if a user takes out the template name, the default index page loads without the proper entry_id causing it to load without the information.
    [Mod Edit: Moved to the EE 2 Technical Support forum]
  • #2 / Jun 20, 2011 1:37pm
    Hi Danny and welcome to the forums 😊
    EE gives you the flexibility to deal with this yourself and define what you want to happen.
    The first thing you can do is turn on Strict URLs
    What I do myself is use the parameter require_entry=“yes” This parameter tells the channel tag that it should expect the URL to contain a valid entry ID or a valid URL title.
    {exp:channel:entries channel="news" require_entry="yes" limit="1"}
    {if no_results}
    {redirect="404"}
    Does that help?
  • #3 / Jun 21, 2011 11:01am
    Danny Valle
    Yes, that makes much more sense.  Thank you very much!
  • #4 / Jun 22, 2011 10:41am
    Kyle Cotter
    Hey Danny,
    Glad to see John Henry was able to lend a hand! If you have any more questions, please post again!
    Thanks.
