I have successfully make my homepage template works fine but when I create a template for a different channel, it wont render correctly using the same relative path I have used for my homepage.
It only works if I change it to an absolute path.
Is this the correct behavior?
Will it be fix if I remove index.php from the URL?
Thanks for your support.
