how can I have inside the atom and rss a space after each article to show Tags and Releted Posts?
June 01, 2011 11:51am
  • #1 / Jun 01, 2011 11:51am
    zupi
    how can I have inside the atom and rss template a space after each article to show Tags and Releted Posts?
    how can I do it? I want to show the tags of each post and below I want to show 5 releted posts
    regards,
    allan
  • #2 / Jun 02, 2011 5:55am
    hi allan,
    You would simply add your tag code and related entries code to the RSS template like any other template
    I would probably add it inside description though as there is no RSS format for tags or related items to the best of my knowledge
    Does that help?
  • #3 / Jun 06, 2011 8:11pm
    zupi
    I’m trying but it’s not working.
    check out:
    {assign_variable:master_weblog_name="zupi"}
    {assign_variable:atom_feed_location="site_zupi/atom"}
    {exp:rss:feed weblog="{master_weblog_name}"}
    <?xml version="1.0" encoding="{encoding}"?>
    <feed >
        <title type="text">{exp:xml_encode}{weblog_name}{/exp:xml_encode}</title>
        <subtitle type="text">{exp:xml_encode}{weblog_name}:{weblog_description}{/exp:xml_encode}</subtitle>
        <link rel="alternate" type="text/html" href="{weblog_url}" />
        <link rel="self" type="application/atom+xml" href="{path={atom_feed_location}}" />
        <updated>{gmt_edit_date format='%Y-%m-%dT%H:%i:%sZ'}</updated>
        <rights>Copyright (c) {gmt_date format="%Y"}, {author}</rights>
        <generator uri="http://expressionengine.com/" version="{version}">ExpressionEngine</generator>
        <id>tag:{trimmed_url},{gmt_date format="%Y:%m:%d"}</id>
    {exp:weblog:entries weblog="{master_weblog_name}" limit="15" category="29|18|19|20|21|25|24|16|17|23|41" rdf="off" dynamic_start="on" disable="member_data|trackbacks"}
        <entry>
          <title>{exp:xml_encode}{title}{/exp:xml_encode}</title>
          <link rel="alternate" type="text/html" href="{url_title_path=site_zupi/index}" />
          <id>tag:{trimmed_url},{gmt_entry_date format="%Y"}:{relative_url}/{weblog_id}.{entry_id}</id>
          {gmt_entry_date format="%Y-%m-%dT%H:%i:%sZ"}</published>
          <author>
                <name>{author}</name>
                <email>{email}</email>
                {if url}<uri>{url}</uri>{/if}
          </author>
    {categories}
          <category term="{exp:xml_encode}{category_name}{/exp:xml_encode}"
            scheme="{path=site_zupi/index}"
            label="{exp:xml_encode}{category_name}{/exp:xml_encode}" >{/categories}
          <content type="html"><![CDATA[
            {body} {extended}
          ]]></content>
        </entry>
    {/exp:weblog:entries}
    {exp:tag:tags entry_id="{entry_id}" backspace="2" orderby="clicks" sort="desc"}
    <a href="http://{path=%27site_zupi/tag%27}{websafe_tag}" title="{tag}">{tag}</a>
    {/exp:tag:tags}
    </feed>
    {/exp:rss:feed}
    the last part exp:tag - it should show the tags, but it’s not.
    http://zupi.com.br/index.php/site_zupi/atom/
  • #4 / Jun 07, 2011 8:25am
    Allan, have you asked over on the Solspace forum? I don’t use this module, but over there they’re familiar with its ins and outs.
  • #5 / Jun 07, 2011 6:18pm
    zupi
    I’ll try,
    thanks
  • #6 / Jun 08, 2011 1:22pm
    Kevin Smith
    Sounds good, Allan. Let us know if we can be of help again.
