I am trying to add pagination to my template, when i set pagination and click on next page or page 2 it redirects to the login screen, when i am already logged in. not able to find where the problem is.
This is my code.
May 31, 2011 5:25pm
Subscribe [1]#1 / May 31, 2011 5:25pm
This is my code.
#2 / Jun 01, 2011 5:54am
alexwolk,
Have you got a link to where this is happening?
Are you using a htaccess to remove index.php?
When you say login screen do you mean a front-end one you made yourself or the control panel login screen?
Are you using any add-ons?
#3 / Jun 01, 2011 12:22pm
http://bootydrop.insiteadvice.com/index.php
After a user logs in he is taken to the main page, when he clicks to the pagination links for page 2 then the user is redirected to the login page of the site, not the control panel.
I’m on v2.1.0 Build: 20100712. addon will be for likee, simple registration
#4 / Jun 02, 2011 10:40am
Hi alexwolk—
Be on the lookout for an email from me. Also, is this happening with all users or just members of some member groups?
Kevin
#5 / Jun 06, 2011 12:21pm
found the solution. it was a url problem thank you for your help.
#6 / Jun 06, 2011 2:31pm
Glad you found a solution, alexwolk. Feel free to post again if you need more help!
Kevin
