Odd issue with mod_rewrite and templates
May 26, 2011 4:26pm
  • #1 / May 26, 2011 4:26pm
    antiuser
    I’m using mod_rewrite to remove index.php from urls - a pretty simple thing that I’ve done loads of times before successfully - but this time it’s giving me really weird results. I have my stylesheets and javascript all in the same template group as the rest of the site, but no javascript or css templates ever load. They are there if I use index.php to access them, but will not load otherwise. Has anyone ever come across this before?
    Here’s my rewrite rule if it helps:
    RewriteEngine on
    RewriteBase /
    RewriteCond $1 !^(images|lm_system|themes|favicon\.ico|robots\.txt|index\.php) [NC]
  • #2 / May 27, 2011 5:30am
    Hi antiuser,
    We actually do not support the removal of index.php by htaccess in the Technical Support forums.
    I am moving this thread to Community Help for you as more appropriate there.
    There is also a community written article on the process in our Wiki which may help
  • #3 / May 27, 2011 3:44pm
    antiuser
    Thanks. I did read that article, but nothing on there seemed to work?
    I should add that my site is built around the Structure module so I only have one single template group, and that I’m not using the EE css tag because my stylesheets use EE variables inside them, so I’m just doing straight {site_url}style.css
    The same issue is occurring with my javascript templates - so in short, anything that isn’t a “web page” template returns a 404, but can be accessed through index.php.
  • #4 / Jun 01, 2011 7:43pm
    antiuser
    Did a bit more testing and narrowed it down to it being the dot “.” on the template name that screws with the rewrite. For example, http://domain.com/style loads, but not http://domain.com/style.css. Changing the rewrite rule flag to [R=301] works, but defeats the purpose as that rewrites the url in the address bar - but it does show that the rule itself is correct, which leads me to believe it’s something in EE that’s causing it not to work. Any help would be appreciated…
