Login problems
May 17, 2011 3:10pm
  • #1 / May 17, 2011 3:10pm
    FCB IT
    Hi, I have a client that has at least two sites that experiencing a problem with logins. It appears to be browser specific, where a user logging in from IE7-8 or Chrome will be instantly redirected back to the login page. We’re at a loss. Halp!
  • #2 / May 18, 2011 1:57am
    Hi rjt35,
    Welcome to the forums 😊
    Does your client have both these sites under MSM?
    Can you add the following to your config.php file and try again please?
    $config['cookie_domain'] = "";
    $config['cookie_path'] = "";
    $config['cookie_prefix'] = "";
    $config['admin_session_type'] = "c";
    $config['user_session_type'] = "c";
    $config['require_ip_for_login'] = "n";
  • #3 / May 18, 2011 2:18am
    FCB IT
    Hey John,
    Quick correction on my part. One of them allows chrome to login, but they both can’t be logged in from IE8, while the other doesn’t allow chrome.
    I added those settings to my config.php, but no change.
    Both are running MSM, and are on 2.1.3 build 20101220.
  • #4 / May 18, 2011 5:21am
    FCB IT
    With some fiddling I found that my MSM sites that have hard coded site_name’s don’t have this issue. I can use their masked cp pages to login fine. I then tested this further by hard coding
    $assign_to_config['site_name'] = 'default_site';
    into my main control panel index.php file and I can login fine after that, with the side effect that the site drop down won’t function.
    So I guess the site_name isn’t being dynamically set? Not sure if this is helpful, but atleast I have some sort of workaround. Should I upgrade things?
  • #5 / May 19, 2011 6:43am
    Dan,
    Can you explain your set-up in a bit more detail please?
    You have 2 MSM sites?
    One or both have a masked control panel?
    What congi options are set in these admin.php fields presently?
    What is in your config presently?(hide any sensitive info)
