Using data from a custom field.
May 09, 2011 4:00pm
  • #1 / May 09, 2011 4:00pm
    iPixel
    I’m relatively new to EE1.x and find myself needing to generate a <select> dropdown.
    I wanted to know if it’s possible and how it’s possible to do so.
    Under Admin > Section Administration >> Custom Section Fields >> Field Group >>> Field (dropdown)
    the field’s name is locations. It contains dropdown info such as California, Utah, Washington etc…
    is there a way to do something like
    {exp:field_groups:custom_fields field_name="locations"}
    <option>{location}</option>
    {/exp:field_groups:custom_fields}
    The idea is to avoid using the ee->$db->query();
    Thanks for the help!
  • #2 / May 09, 2011 5:17pm
    Mark Bowen
    I just answered your same question here in this post.
    There is no way around using a query to get what you want though, be it using the query tag or some PHP or a plugin as there is no built in method of doing so.
    Best wishes,
    Mark
  • #3 / May 09, 2011 5:18pm
    Mark Bowen
    As a note your other post is in the wrong place if you are using 1.x as you have posted it in the 2.x forums.
  • #4 / May 10, 2011 4:16am
    Closing this one out and moved your other thread to Community help forum
