Problem when updating templates
April 15, 2011 5:20am
  • #1 / Apr 15, 2011 5:20am
    Alex Carabi
    Hi guys!
    When I update certain templates within EE2, the update doesn’t work and I’m shown the browser’s standard “this webpage is unavilable” or similar. It’s wierd - it’s only on certain templates.
    Any ideas on what could be wrong?
    /Alex
  • #2 / Apr 16, 2011 9:50am
    Greg Salt
    Hi Alex,
    Which version and build of EE are you using? Is this a local or a remote install? Are you using mod_rewrite rules in an .htaccess file? Are you saving your templates as files and if so, are these files visible and editable on the server?
    Cheers
    Greg
  • #3 / Apr 25, 2011 8:46am
    Alex Carabi
    Hi Greg,
    It’s a remote install of v2.0.2pb01. The templates unfortunately won’t save as files, and they aren’t visible/editable on the server. I am using the following mod_rewrite rules in the .htaccess file:
    <IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteBase /subdirectory/
    RewriteRule ^(.*)$ /index.php?$1 [L]
    </IfModule>
    /Alex
  • #4 / Apr 25, 2011 9:26am
    Hi, Alex.
    Is there a particular reason you haven’t upgraded from that older version of a beta?
    When it comes to troubleshooting, we ask that you rename your .htaccess file and put back in the index.php in your site settings. Does doing that make a difference?
    What kind of a server are you running on?
