I need some assistance with an expression engine/jquery problem.
I am using a jquery plug in to fade in specific products upon page load. This works fine until you hover over one of the listings then it just stops.
You can see for yourself here:
http://www.thecapetable.com/index.php/products/view/category/tableware
What happens is, upon page load each <li> will fade in one at a time, however if you hover over one of the products while it’s loading they will all pause and only a few will be visable.
Anyone know what the problem could be?
James.
