MSM and setting up subdomains
April 10, 2011 3:08am
  • #1 / Apr 10, 2011 3:08am
    erier
    I’ve followed the sub-domain directions to the “T”, but can’t seem to get the functionality I would like.
    When I set up a sub-domain, the defined template-group/template will show up:
    template-group: test | template: index | will show at test.domain.com
    With that said, there are no additional pages showing up that are tied to the template group.
    For instance, if I had a “blog” template inside of template-group “test”, the url test.domain.com/blog does not render and just shows the index template instead.
    I’m sure I’m missing something simple, but this sure is frustrating.
    Any help greatly appreciated.
    FYI: EE2.1.3 - hosted on EngineHosting
  • #2 / Apr 10, 2011 12:44pm
    Neil Evans
    So,... you have a subdomain set up and that is loading a separate MSM site, but you cannot get entries to load within templates within that second MSM site?
    I expect in the control panel you are selecting the second MSM site, and in there it has its own channels, and own templates? And you are trying to load these?
    Or are you trying to load data from a channel on another site, or a template on another site within the msm?
    Either way, are you defining site:
    http://ellislab.com/expressionengine/user-guide/cp/sites/code.html
    Or are you trying to use the pages module to define URLS to make content load?
    Have you updated the index.php to make sure the subdomain knows where the system directory is and which site it should be using by default?:
    http://ellislab.com/expressionengine/user-guide/cp/sites/domainsetup.html
  • #3 / Apr 11, 2011 4:12am
    Thanks nevsie.
    Fat Free Interactive,
    I will await your answers to nevsie’s questions
