404 issue
April 04, 2011 3:21pm
  • #1 / Apr 04, 2011 3:21pm
    Bell Design
    I just setup a small website using ee1.7 and it works great.
    I created a 404 page for the urls have changed.
    I created a template called “404”; placed simple html code within it.
    Went to “Template Preferences” and pointed the 404 page to the 404 template.
    When I go to the site, only the homepage shows its content.
    The other pages show the 404 page I created.
    If I point the 404 page under “Template Preferences” to none, they show back up.
    This is my .htaccess file:
    RewriteEngine on
    RewriteCond %{QUERY_STRING} ^(css=.*)$ [NC]
    RewriteRule ^(.*)$ /index.php?/%1 [L]
    RewriteCond $1 !^(images|system|themes|favicon\.ico|index\.php?) [NC]
    I am removing the index.php and the site is hosted on Godaddy.
    I don’t need to Force URL query strings since I am using a direct url.
    I have this same setup on another small ee site that uses 1.7 on a Godaddy server with a 404 template, the same .htaccess file, not forcing url query strings and it works just fine.
    So not sure what is happening, any ideas?
  • #2 / Apr 05, 2011 6:36am
    Bell Design,
    Can you test first by disabling the htaccess and reinstating index.php in your General Configuration
    If this works then it is your htaccess causing the issue and you can concentrate on that
    You also have this rule twice
  • #3 / Apr 19, 2011 12:52pm
    Bell Design
    Mr. Donovan, sorry for the delay in getting back to you.
    But yes the
    is there twice due to it being on a Godaddy server (yuck I know)
    I am in the process of leaving godaddy as a host all together.
  • #4 / Apr 19, 2011 1:53pm
    Brandon Jones
    Sounds good, let us know if you’re still having issues after the move.
