Hi there,
I recently installed MSM on one of my sites and ran into some problems.
When I want to edit- or publish a new entry some things go wrong:
1) The tab ‘Publish’ is not selected.
2) All costume fields have disappeared.
I’ve read this thread - cause I also updated from 2.1 to 2.1.3.
I have similar problems cause the issue is just happening with one channel which is using the Channel images- and the Freeform addon (I updated them to the latest version).
However, everything seemed to work fine before I started to use MSN. Next to that: the 2nd site (which is using some duplicates) is working fine.
I made a backup of my database before updating - so maybe there’s a way to go back to just one site - and start the whole process with MSM again. I just desperately need a solution, cause my client is getting angry.
Jef
