Categories variable pair not parsing
March 31, 2011 12:09pm
  • #1 / Mar 31, 2011 12:09pm
    EyelightInc
    {exp:channel:entries channel="projects" sort="desc" status="Open|Featured" paginate="top" limit="8" }
          {if absolute_results <= 8 && count == 1}
            <div id="projpgbrowse">
            <div id="projfilterby">
              {if segment_2 == "cat"}
                <h2>{categories}{category_name}(/categories}</h2>
    <p>          {if:else}<br />
                </p><h2>All Projects</h2>
    <p>          {/if}<br />
            </div><!-- end of #projfilterby -->  <br />
          </div><!-- end of #projpgbrowse --><br />
          <div id="projcasewrap"><br />
          {/if}<br />
    I’m trying to display what category you’re currently filtering search results by, but
    wont parse.
    Any ideas? Thanks!
  • #2 / Mar 31, 2011 12:54pm
    Brett Gullan
    ansonleclair, try something like this (not tested):
    <h2>{categories}{if '{segment_3}' == '{category_id}'}{category_name}{/if}{/categories}
    ... I’m assuming {segment_3} contains the Category Id of the category you want to display.
    HTH
  • #3 / Mar 31, 2011 2:51pm
    EyelightInc
    thanks for the reply Brett,
    segment_3 actually contains the Category URL Title.
    I tried:
    <h2>{categories}{if '{segment_3}' == 'water_service'}{category_name}{/if}{/categories}</h2>
    and the if statement processed, but I still see displayed on the webpage:
    {categories}{category_name}{/categories}
    instead of it displaying the value of the variable {category_name}.
    I’m using pagination, could that be affecting it?
  • #4 / Mar 31, 2011 8:26pm
    Brett Gullan
    ansonleclair, have you checked your code (syntax)? I noticed your closing {/categories} has a round opening brace (not a curly one)!
  • #5 / Mar 31, 2011 8:33pm
    Brett Gullan
    Also, if you only want to display info for the Category currently being displayed, try using this tag:
    http://ellislab.com/expressionengine/user-guide/modules/channel/category_heading.html
    B.
  • #6 / Mar 31, 2011 8:34pm
    Brett Gullan
    This extension might be better still ...
    http://loweblog.com/software/low-seg2cat/
  • #7 / Mar 31, 2011 11:01pm
    ansonleclair,
    Let us know if Brett’s advice is helpful.
    I would usually use the Category Heading tag in this instance
    {if segment_2 == "category"}
    {exp:channel:category_heading channel="projects"}
    <h2>{category_name}</h2>
    <p></div><!-- end of #projfilterby -->  <br />
    {if:else}</p><h2>All Projects</h2>
    <p>{/if}</p>
    <p><br />
    {/exp:channel:category_heading}<br />
    {exp:channel:entries channel="projects" sort="desc" status="Open|Featured" paginate="top" limit="8" }<br />
        <br />
        <br />
  • #8 / Apr 01, 2011 10:54am
    EyelightInc
    Brett and John thanks so much, that got it working! I wound up using the {exp:channel:category_heading} tag you have both suggested.
    I guess you can’t use the {categories} variable pair in a pagination area, that was my only issue. I’m not sure why, is it because you can’t nest any type of tags like this?
    Thanks again!
  • #9 / Apr 04, 2011 11:40am
    Hi, ansonleclair.
    Sounds like you have a solution—Feel free to start a new thread if you have any more questions.
  • #10 / Apr 04, 2011 11:40am
    Now really closing..
