I just noticed that the edit entry filters are missing on a site I’m currently developing. I can’t for the life of me figure out why this top panel section is missing. Any ideas?
March 15, 2011 6:07pm
Subscribe [2]#1 / Mar 15, 2011 6:07pm
#2 / Mar 16, 2011 12:23pm
Hi, stubear. What sort of third party extensions are you using? If you are using any, try disabling all your extensions at once by clicking the big green button titled Disable Extensions..
Is this a new EE install, or an upgrade from an earlier version?
#3 / Mar 16, 2011 3:27pm
I thought I had done that but apparently not, or at least I missed the one that was causing the problem. MD Show Expired apparently has problems with EE 1.7.0. Problem solved and I’m back to developing unhappily away (not EE’s fault, the client’s).
#4 / Mar 17, 2011 9:59am
I feel your pain. 😊 Glad you were able to find out which add-on was causing the problem. Feel free to start a new thread if you have any more questions.
